explain how I am hitting almost 6300 rpm?!?
Old Apr 19, 2004 | 12:29 AM
scoobysnax83's Avatar
I have a completely untouched PCM in every way shape and form, yet I am able to hit almost 6300 rpms. Here is the proof... datamaster image
I know that the PCM has never been reconfigured. Why would I be able to hit this rpm if the stock is supposed to be 5600 or 5800 or whatever. I have argued this to a tee and now I have an image to back me up. I am just curious why the rev limiter doesn't hit sooner.
Thanks everyone
Old Apr 19, 2004 | 12:49 AM
screamin94Z's Avatar
you sure whoever you got it from didnt use a hypertech on it? mine reset the rev limiter to 6200, and you can put it as high as you want to go. i'd check with who you bought the car from, assuming you're not the origional owner.
Old Apr 19, 2004 | 12:53 AM
I bought it from a 75 year old lady. I know for sure that nothing has been done to it.
Old Apr 19, 2004 | 01:22 AM
Jason Dove's Avatar
Sure the tranny isn't slipping? Can you scan through your logs and see how long it spends between your rev limiter and the max rpm hit?
Old Apr 19, 2004 | 01:38 AM
I'm not quite sure how I would do that, but I am pretty sure that clutch slip (I have an M6) is not the cause. Does Datamaster or Freescan show the rev limiter anywhere?
Old Apr 19, 2004 | 02:03 AM
Jason Dove's Avatar
Does it only happen in first, or does it happen in second/third also?
If it's a M6 Ignore the slippage statement...
Old Apr 19, 2004 | 02:08 AM
well, it says 6275 at 69mph, so I assume that it is 2nd gear.
Old Apr 19, 2004 | 02:16 AM
something's wrong here. It says a few records back that I was doing 72mph at 5875rpm. So, I must have let off the clutch before the gas
But I have a few spots in my log file that I am hitting 5900rpm consistently. Why is it allowing itself to rev that high in any case?
Edit: I'm going to go out tomorrow and try to determine if I can hit 6000+rpms consistently or not. I'll let you all know.
andrewcapps82
May 19, 2015 10:11 PM
BigWil
Mar 29, 2015 12:24 PM
NewsBot
Mar 13, 2015 07:15 AM
mark0006
Feb 3, 2015 05:12 PM
kev93z28
Aug 19, 2002 12:48 AM
