View Poll Results: Which exhaust on a heads/cam LT1 for best performance?
E-Cutout on the Y-pipe.
18
26.87%
Used Hooker/Just buy muffler somewhere.
7.46%
Used Borla
12
17.91%
GMMG
19
28.36%
Mufflex 4" w/Spintech.
13
19.40%
Voters: 67. You may not vote on this poll
Which exhaust would you run (On HC car)? Poll.
Re: Which exhaust would you run (On HC car)? Poll.
I disagree with just about everyone here.
I think you're CRAZY if you don't cut the Flowmaster out of your piping and install a new Aerochamber.
I had an Aerochamber on my Vortech T-trim 383 combo. When I removed the whole cat-back from the y-pipe, I gained only 5 rwhp on a 550 rwhp combination. Thunder Racing has had similar experiences with high hp NA applications. 480 rwhp NA through a 3.5" Aerochamber and no discernable gain when the muffler is removed.
How is a $200 e-cutout more cost effective than a $60 muffler???
I hate when people talk about how great the bang/buck is on an e-cutout. A good muffler is almost always way less money!
As far as Spintech goes, you might as well keep your Flowmaster. . .
Mike
Mike
Hmm ... Them Aerochambers must be pretty decent ...
Anyone have a link to where they had the CFM's of a buncha different mufflers?
I wanna see what some of the ones I like flow like compared to an Aerochamber.
I think mine sounds way better than an aerochamber does, but I would rather have function over sound anyways ... I would have a harder time I think getting it stickered with a E-Cutout than I would with an Aerochamber, or even true duals ...
Wonder, on a HC car, how big a gain there would be going true duals over an Aerochamber ... I know it would peak better, but most of my driving will be down low anyways ...
Anyone ever do a true dual vs. good catback, back to back dyno ?
Originally Posted by James Montigny
Do you guys have pics of where you put your cutouts?
I'm pretty much out of space between my Y-pipe and my cat.
I wonder if swapping my flowmaster muffler for a hooker aerochamber would be worth it.
I wish someone on here had some dyno results to show the difference between flowmaster and something like a aerochamber, and then the differnece between a "good" cat back like a aerochamber and true duals, or a Ecutout.
Owell.
I just dont want to choke the motor up with the new set up I build this winter.
Owell.
When I dropped my 3" Aerochamber cat-back from my 550 rwhp S/C 4th Gen, it picked up only 5 rwhp.
You do the math.
True duals with spiral flows out the back under the axle. I don't know why everyone is scared to go under the axle, you have the exact same ground clearance as you would if you dumped them.
Owell.
Owell.
Just to add something else, back when I had a hooker catback, in the same night, same conditions, I ran 2 passes, similar 60's, and trapped 114.3x both times, then I unbolted the hooker muffler and trapped 115.1x the next 2 passes. I never had a chance to dyno the car with it on/off though. And all my runs were within 1 tenth that night, so the car was running consistent as hell.
I have to also say that cut outs just make the car loud... not fast. I like the SLP 2otl. It's not shrill or harsh, and it won't get you pulled over driving home from the bar. I dyno'd the car with the 2otl and then dropping the y- pipe (open hooker lt's), and the car lost 3 rwhp with no exhaust. Loud cars are annoying. If there is one thing I hate, it is a car soooo loud that your ears are bleeding but the car only runs 12.3. Or even worse a mid 70's f-body that runs 15's tuned up (open hedder of course for the MOST POWER EVER!!!), and I can't even tell my car is running when I am parked next to a guy like that. But hey, it's LOUD....so it must be superfast!
Here is what my car sounds like
http://videos.streetfire.net/search/...f885a869e4.htm
... and at the track
http://videos.camaroz28.com/search/9...904a07731b.htm
