Which exhaust is quieter?
Old Jun 7, 2004 | 03:34 PM
Tom R.'s Avatar
Don't flame me.
Im too old and tired for a loud exhaust - thats what my 68 is for.
I was happy with the stock exhaust on my daily driver (baby seat totin) '93 Z28. Then last week I realized the muffler is rotted from the inside after i picked up another 944S2 weekend/DE car.
I'm looking for a cat back that is as quiet as possible.
which is quieter, the flomaster, edelbrock, or SLP SS single outlet system?
Old Jun 7, 2004 | 03:36 PM
Camaro_Maniac63's Avatar
Definitely the SLP one.
Old Jun 7, 2004 | 03:41 PM
My 97 Z28's Avatar
Personally the quiestest I have heard is stock . Edlebrock is really quiet. Flowmaster is loud, my magnaflow was supposed to be quiet and i take it to me louder..... I say edlebrock
drewstealth's Avatar
The SLP one is the quietest out of those. You may wanna look at the Hooker or Magnaflow also.
Old Jun 7, 2004 | 04:28 PM
Cmr0z28's Avatar
I can't even hear my Hooker at idle/cruising, but at WOT it has a deep screaming tone
Old Jun 7, 2004 | 04:32 PM
agent z28's Avatar
Ditto on the Hooker noise level. Below 2000 RPM the difference over the stock system is negligible. After that it builds to a nice roar.
Old Jun 7, 2004 | 04:38 PM
Mindgame's Avatar
Out of those three... the SLP.
If you want really quiet, the B&B system is about the quietest I've heard.
-Mindgame
Old Jun 7, 2004 | 05:07 PM
RedHottG2's Avatar
The SLP loud mouth is the quietest I've heard yet.
Naw, but seriously the SLP SS single outlet is pretty dang quiet. Might be your best bet for what your looking for.
Old Jun 7, 2004 | 06:08 PM
n2oblkz
Guest
Posts: n/a
Quiet Exhaust
I've got the SLP Dual/Dual on my car with Hooker long tubes and a muflex 3 inch Y pipe. I went from a Flowmaster cat-back to the SLP and I was shocked at the difference. The SLP nearly sounds stock at idle and cruise but when you open it up, it sounds really healthy, with no drone at cruise!
Dynojet results
Motor: 300.3RWHP 314.RWTQ
75 Shot: 343.2RWHP 379.5RWTQ
100 Shot 404.8RWHP 469.0RWTQ
150 Shot 443.7RWHP 514.2RWTQ
Black 1996 Z-28, 6spd with Pro 5.0 and Lou's Short Stick and MBA ****, K&N cold air, 52MM polished TB, Granatelli Mass Air Flow sensor with polished ends. Crane valve springs, Comp hardened push rods w/guide plates, Comp Pro Magnum roller rockers. Hooker ceramic coated long tubes with mufflex Y pipe, SLP Dual/Dual Cat back. MSD 6A, MSD coil, MSD plug wires, NGK TR6 plugs. March underdrive pulleys. Auto meter electric Fuel pressure and nitrous pressure gauges in pod and Scanmaster. Granatelli 255lph in tank pump. Aeromotive adjustable fuel pressure regulator. 6AN braided fuel lines rerouted from factory location. DMS drop springs, BMR control arms, adj. panhard rod. Spohn weld-on lower control arm relocating brackets. Enkei Win wheels with 275/40/17's in front and 315/35/17's in back. Polished aluminum radiator cover, polished aluminum valve covers, polished aluminum Vortech elbow, chrome alternator, ceramic coated intake, ceramic coated water pump housing with Mezeire Electric water pump, ceramic coated accessories bracket and TNT F-1 nitrous kit with purge, NX bottle opener and NX bottle heater.
Old Jun 7, 2004 | 06:23 PM
truedualws6's Avatar
Although it was not not one of your choices, I recommend
a Dynomax Ultraflow. Quieter than stock on the inside and
a bit louder on the outside.
Old Jun 7, 2004 | 07:00 PM
Tom R.'s Avatar
the SLP is about $150 more then the edelbrock or flowmaster, but it is all stainless while the edelbrock is only a stainless muffler.
i didnt see much on the dynomax, isnt that made by walker?
the guy at summit thought the flowmaster would be quieter then the edelbrock, thats why i put up a post here. i read the flowmaster isnt the most efficient.
probably go for the SLP unless the dynomax is much less than the other two.
Old Jun 8, 2004 | 08:41 AM
Tom R.'s Avatar
Magnaflow, how much louder than say the the SLP SS system or the flowmaster?
does anyone have a picture of what the rear looks like with the magnaflow?
again
TIA
Old Jun 8, 2004 | 08:52 AM
Yes, the Dynomax is Walker. It's also about the same internal
design as the Magnaflow. I would avoid the Flowmaster if you
want quiet since they can be much more resonant inside the car.
Old Jun 8, 2004 | 09:02 AM
Tom R.'s Avatar
SLP want $440 for their single outlet SS system, I can get a Magnaflow for $265. I am living with the stock system with a rotted inside, but would like it quieter, and don't want to deal with rust since i live by the ocean.
so am I correct the Magnaflow shouldn't be much louder then the SLP, but quieter then the flowmaster or loudmouth?
Old Jun 8, 2004 | 09:12 AM
Cmr0z28's Avatar
Yup....MUCH quieter than flowmaster and the loudmouth
