exchanging tranny fluid good or bad?
well my dad says i should if it wasnt bright red, so i looked and it was a dark red and what would this do for me?
is it good to get the fluid changed? |
Man this is seriously the most controversial topic ive seen that deals with cars. I asked a few times, I get half yes, half no. I think the main thing is that if you replace it on a good basis(like every 30k miles) then you can continue to replace it, but if its been like 90k miles, then leave it be. If you start to feel your tranny slipping, DONT change it, or it will go out. The little shards of stuff are actually stopping leaks and holding the tranny together(or somethign like that). When was the last time it was changed?
i already did it but im wondering if it was a good idea
but i just bought the car 86k |
i never change tranny fluid.. seems to cause more problems than it fixes, if the fluid isnt regularly changed..
just from my personal experience 85 e150, 308,xxx no flush runs fine 96 saturn SW2 250,xxx same 94 z28 130,xxx same these are the automatics that i own |
if its never been changed and you changed it,then your probably going to be out some money down the road.
get some Lucus transmission additive and put it in maybe that will help? |
