Everyone using GM Extreme Duty Timing Set - Please Read!
Old Mar 6, 2003 | 04:14 PM
Mikey97Z's Avatar
Arrow Everyone using GM Extreme Duty Timing Set - Please Read!
I have two questions for those using the GM Extreme Duty timing set:
1) Did you install the new water pump gear that came with the set?
2) Does your timing set make any noises?
Please post your experiences ... I'm trying to locate my problem.
Thanks!
Old Mar 6, 2003 | 04:33 PM
jmzlt1's Avatar
Yes, I did install the water pump gear. The gear is pressed on the shaft. You need a press to get it out or a tool from kent moore. My dad is a machinist so we came up with a way to remove it and install it where it belongs. Works great, no noise at all. I'm happy with it.
Old Mar 6, 2003 | 05:03 PM
gb95zconv's Avatar
I didnt use the WP gear because I have an electric WP. The assembly works fine and makes no more noise than the stocker.
HectorM52
Jul 30, 2017 11:46 AM
CARiD
Jan 14, 2015 04:00 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
jim88iroc305
Aug 13, 2002 09:24 PM
