Ever shipped an engine?
Old May 20, 2005 | 02:42 PM
jimlab's Avatar
If so, who did you use and how much did it cost you? (Details such as liftgate service at both ends, etc. would be helpful also)
I've gotten some estimates, but all the major shippers have been incredibly expensive ($500+) while some that I've never heard of are far more reasonable ($160-280). Any recommendations?
Thanks!
Old May 20, 2005 | 02:57 PM
lt4 fd's Avatar
Re: Ever shipped an engine?
AAA Cooper if you are in the South East Mine was 225 shipped from florida to Texas and all I had to do was go to the hub and pick it up...
BUBBA's Avatar
It's just like anything else, shop around and take the best deal.
When I ordered my short block from the other side of the state, a couple hundred miles, it was delivered to the mechanic the next day for around a hundred bucks.
Most likely it would be delivered by truck on a pallet. So it depends on when they have a truck going your way (or a train if waaaay cross country) and whether you have them pick it up from your place, etc.
Again, just shop around, there's lot of competition.JMHO
Old May 20, 2005 | 03:04 PM
jimlab's Avatar
It saves a little wear and tear to have a better idea of where to shop first...
Old May 20, 2005 | 04:06 PM
OldSStroker's Avatar
Thanks!
This can be a can of worms ...
Best pricing is when it's coming from someone who has a "deal" with a major carrier like Yellow Freight or Roadway, is not a single shipment on that particular pickup, no lift gate is required and it's going to another business or a local terminal where you pick it up.
Another problem is packaging and declaring a value. I would suggest an engine stand like Jeg's P/N 550-1005 bolted to a pallet and then enclosed in a box made from plywood which fits over the entire engine and bolts to the pallet. The pallet should be big enough that the engine won't tip over if it is rocked up 30 degrees or so.
Unless you specify a value, you'll only get back so many $/lb if there is damage or loss. I'd be hesitant to ship an expensive engine like yours, Jim, without insuring it for replacement value. That's another reason to cover it completely with a crate. It's less likely to attract attention. Declared value boosts the cost, of course.
Would I ship a $15K engine on less than a name carrier without a declared value? Not a chance!
How far are you shipping it? If it's less than a day's drive, the safest way is to schlep it yourself in a pickup, or even a rented SUV! I've seen that done by an engine builder.
Old May 20, 2005 | 08:35 PM
jimlab's Avatar
No problem on the packaging...
http://www.rx7club.com/attachment.ph...d=113354&stc=1
http://www.rx7club.com/attachment.ph...d=113355&stc=1
Yep.
St. Louis is more than a day's drive, unfortunately.
Old May 20, 2005 | 08:55 PM
1racerdude's Avatar
Thanks!
Just left Spokane a few months ago.
I got a engine storage stand and used nylon straps to hold engine on then built a plywood crate and used more straps to hold it in place. I built it 3 sides and a bottom,put it in the truck and used the cherry picker to put engine in crate,finished crate in truck and took it to Overnight Trucking. They took it off with a forklift. Cost $326.00 to ship to Mobile. Picked it up at the depot and they loaded it with a forklift.Brought it home and reversed procedured it and put it on engine stand. Crate was 3/8" plywood 4x4's underneath and 2x4 corner's cost about a hundred for wood,screws and banding.The crate and engine arrived without a scratch,but I tend to over build stuff and ya could have run a dozer over the crate and not hurt it.
Old May 20, 2005 | 09:12 PM
ejfagala's Avatar
Yep done it a couple of times.
I believe it was around $350 -$400 to send my last motor from Charleston To Wisconson. I used Forward air and droped it off at the terminal. Another note, If you can find a local parts store or engine swap place that has a spare engine crate it shre makes life a lot easier, sometimes a local dealer will even have one.
Old May 20, 2005 | 10:15 PM
jimlab's Avatar
Thanks folks, but I don't have a problem with crating the engine. I have the plastic engine crate that it arrived from B&B Performance in.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
willismoons
Feb 14, 2015 08:42 PM
Jlo
Feb 3, 2015 09:41 PM
