Ever installed pistons from bottom? (to avoid removing heads)
Old Nov 21, 2008 | 10:48 PM
blue's Avatar
Has anyone installed pistons from the bottom of the block? The problem of course will be getting the rings in there, but the advantages are not buying new head and intake gaskets, saving two days plus of work taking everything on the top of the engine off, and cleaning all the surfaces, and not having to pull the engine out. I'm going to do this is I can, but if someone says they've tried it and it's impossible, that would save me a lot of time in a failed effort.
Old Nov 22, 2008 | 12:19 AM
94FBIRD's Avatar
Won't work. The piston won't clear from the underside.
Old Nov 22, 2008 | 04:03 AM
96m6lt1's Avatar
big negative!
Old Nov 22, 2008 | 08:05 AM
Impossible.
Old Nov 22, 2008 | 08:55 AM
user 647483's Avatar
You can't get a crank and rods (nor the pistons) out with the motor in the car.
It's tough enough raising it just to get a pan off.
Removing cyl heads is the least of your problems.
Besides, as pointed out above, it won't work.
Old Nov 22, 2008 | 09:17 AM
jasonface's Avatar
As noted, it won't work on a SBC. I had a friend do a ring jod on a Ford V6 years back, and he was able to do it fron the bottom. I think it took him more time than it saved, but it was an interesting job anyway
Old Nov 22, 2008 | 09:45 AM
sam pace's Avatar
The only one you can do this with is cyl. no.7
Old Nov 22, 2008 | 11:04 AM
blue's Avatar
I should have mentioned, the crank will be out, so the trans will be disconnected also. I had planned to hold the engine with a piece I'm borrowing; it sits on the fenders and holds the engine with chains. So I think I can get enough clearance from the cradle to be able to pull the pistons all the way out. It's getting them back in that I think might be a problem because of the rings.
edit: Maybe I should ask: if you had the block out and on a stand, could you put the pistons in from the bottom? :edit
Old Nov 22, 2008 | 11:06 AM
sn8ke eatr's Avatar
piston swap with motor in the car.. probbaly bad idea.
on a stand, would it still not work?
Old Nov 22, 2008 | 12:52 PM
Way better to do it right (heads off) and probably easier, too. I don't know why anyone would even consider trying it from the bottom.
Old Nov 22, 2008 | 12:53 PM
RUDEDOG's Avatar
No way.
Old Nov 22, 2008 | 11:09 PM
jasonface's Avatar
Again, this is not possible due to the block casting. The main web is in the way and you cannot remove the pistons from the bottom.
Old Nov 23, 2008 | 06:43 AM
bombebomb's Avatar
*cough*
https://www.camaroz28.com/forums/sho...d.php?t=594865
As everyone already said, no way no how. And I already asked haha, once I got it out, it was quite clear it was impossible.
Old Nov 23, 2008 | 07:38 AM
Guest47904's Avatar
Guest
Why would you want to replace the bottom end without the top end being massaged???
For performance??? What a waste. If you are upping CR, what's gona happen with an old head gasket???? Not to mention putting new rings in an un-touched cylinder. That's real smart.
For repair? How would you know without looking in from the top? Using a bore scope maybe.
I want to see you compress the rings to get the pistons back in from the bottom
You want to save the intake gasket and head gasket but do some sort of bottom end work.
You are stepping over dollars to pick up pennies.
Old Nov 23, 2008 | 10:30 AM
MachinistOne's Avatar
If this get's moved to advanced tech, maybe someone can figure out how to do it
