Ever hear this noise when....
Old Aug 27, 2004 | 12:48 AM
nj87ttype's Avatar
A lot of the time when I put my car in reverse I hear a weird noise coming from the rear end when I begin to back up. Its not a very loud noise, I usually have to turn my radio down to hear it good but it sounds really funky. Kinda like a dog in pain or something. Could this mean my rear end might be loose? My car has only 39,000 miles on it. Any info is appreciated.
Old Aug 27, 2004 | 10:55 AM
Bad64chevelle's Avatar
Re: Ever hear this noise when....
NJ my car has low miles on it also...and it makes the same noise. I bet if you got under your car and looked above the rear end where the drive shaft meets the rear you will notice you have rear end gear oil ALL over your floor pans...mine does! The seal in the front of the rear is leaking and you need to add some fluid (reason its squeeling)...i add about a 1/2 quart of fluid every time i change my oil (every 2500 miles). I dont have the time nor patients to fix the seal as of right now...im gonna save up the $$ so i can toss some 3:73's in there or maybe 4:10s at the same time i change that seal!
Hey is there any chance that you just purchased that Car recently?
Jon
Old Aug 28, 2004 | 12:11 AM
nj87ttype's Avatar
Thanks for the info. Yeah I actually just bought it a couple of months ago. -Dave
Old Aug 28, 2004 | 12:21 AM
You didnt happen to buy it on the corner of Route 68 and 206 at a gas station did you?
Old Aug 28, 2004 | 01:54 AM
nj87ttype's Avatar
I bought it from Willow Grove Automotive, which is in Willow Grove, PA.
Old Aug 28, 2004 | 04:22 PM
ahh ok Never mind then...there was a car just as you describe yours right near me....i was just wondering if it was the same vehicle
Old Aug 28, 2004 | 04:26 PM
chrism400's Avatar
My car made that noise and I found it to be a sticky rear caliper.
Old Aug 28, 2004 | 09:25 PM
nj87ttype's Avatar
Thanks again for the info guys.
Aaront810
Aug 29, 2020 09:34 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
