Ever hear of coolant in the oil because of a leaking head bolt?
Old Apr 21, 2003 | 08:03 PM
94 CAMRO Z28's Avatar
Question Ever hear of coolant in the oil because of a leaking head bolt?
Since last fall my car would start ruff and I was getting moisture in my oil. It seemed that it was just a cold start gasket leak that sealed back up as soon as it ran for a little bit. I pulled the heads a week ago and the very back/upper head bolt on the driver side was really corroded/rusted almost. Seems that coolant was leaking through the threads as if the thread sealer failed and then it worked its way in through the gasket somehow? Has anyone ever heard of this happening? I haven't, but Im guessing that was the problem, new gaskets and a set of ARP bolts and all is well now. Except for the new exhaust leak I now have
Aaron
Old Apr 21, 2003 | 09:08 PM
RicocheT's Avatar
yea it happens.. the head bolts go down into the water jacket so you need to use permatex when you put them in.. I hate using the stuff but it works!
Old Apr 22, 2003 | 02:40 AM
Yea thats what I used when I put the new bolts in. The instructions said use the ARP stuff only but I figured the other stuff will do just fine. So far so good...
Aaron
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
