EVAP Solenoid help please 94 z28 A4
Old Mar 12, 2013 | 11:54 AM
cmcl3m0r3's Avatar
I have looked all over the web and under all forums, even the shop manual on this issue and its driving me nuts. I bought this car not running and pretty much a basket case. Long story short, car is running and has been for a while and I am trying to get the minor details worked out.
The issue: one of the lines was capped off from the solenoid on the passenger side, EVAP Purge solenoid from what I understand. The line to the charcoal canister is hooked up, according to diagram in picture is the bottom line of the solenoid(this is correct). However, the top valve (shown to go to the throttle body, via emissions diagram) has been long disconnected. I am trying to simply figure out which port on the TB that this line goes to. My breather from passenger VC is connected to the top port, and the 2nd port (right underneath top port) is capped off. I am not entirely sure that the the person that hooked this up did this right, and connected the right lines to the right place. Every diagram and picture that I look at does not show exactly where the lines hook up, so this is where I hoped that someone would know.
Thank you for any and all help.
Old Mar 12, 2013 | 12:18 PM
Re: EVAP Solenoid help please 94 z28 A4
Well, the emissions sticker says the CCV hose goes to the top vacuum fitting on the TB, so the EVAP has to go to the other one (just below). It's the only place it can go. There are no other vacuum ports on the TB.
Old Mar 12, 2013 | 01:15 PM
cmcl3m0r3's Avatar
Thats what I thought, just wanted to double verify this. Since both ports look very similar to coolant ports... it can be confusing. Plus I am tracing down a vacuum loss, and this was the first place I wanted to start. Thanks for the help. It really is very hard to find the actual schematic for this, even on SHBOX. All diagrams show cutaways at the TB.
Old Mar 14, 2013 | 08:26 PM
squarehead's Avatar
Shoebox is correct the line connects to the smaller port just under the breather line from the valve cover. On my 95 the hard plastic line comes out of the solenoid then there is a rubber 90 degree hose that connects to the throttle body.
Old Mar 15, 2013 | 09:11 AM
bw_hunter's Avatar
Lol Rob is always correct about this stuff!
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
bandit383lt4
Dec 21, 2014 09:12 PM
blac94Z
Nov 28, 2014 01:53 PM
