et times
a 306 cam is to big for stock heads you would be better off using a LT4 hot cam or a 305 the stock heads cant take advantage of the lift and duration on that cam. with a 305 2800 stall and long tubes you could see mid 12s with good tuning
there is a guy on the board who has stock heads, lontubes, 306, and is running 12.7s. the 306 is not to big for stock heads.
ChrisFrez
Feb 1, 2015 08:26 AM
