ES Engine Mounts
Old 07-09-2006, 11:22 AM
LT1_383's Avatar
ES Engine Mounts
Anyone have any trouble with ES mounts sagging? I thought they would be less prone to sagging over time then the stock mounts but apparently i was wrong. There's probably a little less then 10k miles on these mounts and out of no where the header is starting to buzz against the engine mount clamshell on the passenger side and the bolt for the streering shaft is rubbing on one of the primaries now. Last time i had the mounts off it seemed like the passenger mount could move around a little in the clamshell too.
Anyone else have this problem? I'm thinking about going back to stock replacements.
LT1_383 is offline
Old 07-09-2006, 12:09 PM
Kevin Blown 95 TA's Avatar
Re: ES Engine Mounts
Never heard that yet, but one of the guys said his melted from header heat.
Kevin Blown 95 TA is offline
Old 07-09-2006, 04:45 PM
LT1_383's Avatar
Maybe the heat causes them to dry out a bit and shrink. Either way i think i'm throwing in new GM mounts soon. The poly motor mounts don't really give noticable performance gains, just new vibrations anyway.
LT1_383 is offline
Parts Wanted
03-17-2015 11:24 PM
Jason Short
01-19-2015 06:34 PM
CaRParts102
12-06-2014 08:45 AM
07-04-2005 05:00 PM
Quick Reply: ES Engine Mounts
