Ensuring Both tires spin during burnout?
Old Feb 22, 2004 | 04:18 PM
SlickBlack Z's Avatar
I pulled a 1 legger brakestand the other night, and im worried. Is there a method to ensure both tires spin during a burnout? Like start out at a low RPM or something? Im going to the track Sunday and Im concerned about my rear's integrity. Is this a sign of the clutches in the rear wearing out, or is this common from time to time? Usually my posi works fine. Any info appreciated.
Old Feb 22, 2004 | 04:19 PM
FacelessZ's Avatar
do you have a stock posi?
Old Feb 22, 2004 | 04:21 PM
JDBlaze85's Avatar
just get the tires a lil wet and drop that clutch!
this used to happen in my 94 M6 T/A
it would happen if I was too soft on the gas.
Old Feb 22, 2004 | 04:47 PM
The Rear is completely stock. 3:42 gears.
Old Feb 22, 2004 | 05:25 PM
CamaroSS30thAnn's Avatar
usually a car with a posi rear spins one tire that means the rear end posi unit us f*ucked.....should replace
Old Feb 22, 2004 | 05:51 PM
Like My Taillights?'s Avatar
SLP sells a take out differential for around $100. The dealership wanted $400+ for the same item. I paid another $100 to have it installed. Its not something I would do unless you know about setting up a rear end properly. My car had the same problem, and i bet that as time goes on your rear will get worse. On the bright side, It's cheaper to only replace 1 tire insted of 2
Differential $100
Installed $100
Seeing 2 long black streaks in the rear view Priceless
Old Feb 22, 2004 | 06:03 PM
Where did you get it installed...a transmission shop? Do you have an SLP part #? Why didnt you upgrade to the Torsen?
Old Feb 22, 2004 | 06:32 PM
No, there is a speed shop nearby, but I'm sure any decent garage could do it. I didn't think it was worth it to upgrade because I have big plans for the car and I'd like to get a 12 bolt eventually. Check out SLPonline.com
Latronaxe
Jul 20, 2015 12:00 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
