engine/trans setup
Old Nov 1, 2011 | 06:25 AM
  #16
Lilatlboy6969's Avatar
Re: engine/trans setup
ok... guess i'll go with OEM LS7 lifters... i can get those through my job for a decent price im sure of since i heard dealerships could easily order those.
for the trans cooler i've got some ideas just gotta get my hands on my car when i get home to figure out the route i wanna run the lines
Old Nov 1, 2011 | 06:28 AM
  #17
RamAir95TA's Avatar
If your car is an automatic you already have an OEM trans cooler that's routed through the radiator, so all of the lines are already there. It's just a matter of splicing the lines together. It's literally a one hour install.
Old Nov 1, 2011 | 07:00 AM
  #18
oh... now i think i understand what you mean by the trans cooler... run an external one along with the oem one and hook em all together... makes hell of alot more sense to me now. atleast i hope im right about that
Old Nov 1, 2011 | 07:09 AM
  #19
RamAir95TA's Avatar
Yep - you run them piggyback'd. I have a B&M Supercooler in conjunction with the stock cooler. Works awesomely.
Old Nov 1, 2011 | 07:13 AM
  #20
thanks for the advice and help throughout all that, as well as your patience. now i just gotta make 100% sure all that will work together without any complications or machine work before i get it all put in. any tables or anything online that i can put numbers into to make sure it will all fit well?
Old Nov 1, 2011 | 07:19 AM
  #21
RamAir95TA's Avatar
What do you mean, about the transmission cooler? Any cooler will work/fit. They attach to the front of the radiator (or you can alternately mount them elsewhere) and all of the lines are very easy to run/cut/splice. There's no machine work or complications. Hell there aren't even any bolts to hold it to the radiator, just a few plastic clips, two lines to run to the OEM lines held in with a few worm clamps, and you're done.
Old Nov 1, 2011 | 07:27 AM
  #22
guess i should have been more exact.. i meant the whole engine setup, like the cam, lifters and so on.
i got the whole trans cooler down.. thats too easy to figure out when i get home
Old Nov 2, 2011 | 08:59 AM
  #23
I decided to just go with one of Lloyd Elliot's packages with heads/cam
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
FryedClutch
Sep 1, 2015 08:24 AM
detroitmuscle
Jul 31, 2015 04:21 AM
