engine temp sensors
Old Sep 7, 2005 | 06:17 PM
ruggerz28's Avatar
engine temp sensors
i pulled the wire off of the temp sensor in the front of the motor cause the fan would no kick on and the car was running really hot, like hovering just under the red, now it runs a lot cooler but the problem is that now its hard to start and the ses light is on. I was wondering if these two are related or if something else is wrong
Old Sep 7, 2005 | 06:52 PM
Dave89IROC's Avatar
Re: engine temp sensors
the PCM needs that sensor for correct fuel trim, which is why the SES is on and it starts hard, you need to find out why the fans arn't working correctly,or what else is wrong with the cooling system, with that sensor unplugged, the fans run consantly anytime the key is on
Old Sep 7, 2005 | 06:53 PM
Dave89IROC's Avatar
it is possible that the temg gauge is incorrect, temp might be fine...........
Old Sep 7, 2005 | 06:58 PM
Robs97Z28's Avatar
There two sensors, the one on the water pump is for the fans and the one on the drivers side head is for the coolant temp sensor.
Old Sep 7, 2005 | 07:03 PM
The one in the water pump is more important than just the fans as Dave mentioned.
Old Sep 7, 2005 | 10:48 PM
ruggerz28's Avatar
can yall please help me out and give me some troubleshooting tips so that i can figure out what is actually wrong
Old Sep 7, 2005 | 10:50 PM
You can find cooling system testing tips in the "How To" section of my Tech Page.
Old Sep 7, 2005 | 10:59 PM
Robs97Z28's Avatar
Robs' tech pages are awesome!! me has gone to a lot of work to put all the info on there. everything you wanted to know about a F-body is there.
Old Sep 8, 2005 | 02:12 AM
smoknta's Avatar
When you say your car is running hot...Define hot. LT1's stock run around 210-220.
HectorM52
Jul 30, 2017 11:46 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Cam28_boy
Aug 6, 2002 08:40 AM
