Engine storing suggestions or recommendations
Old Oct 6, 2011 | 07:32 AM
undecidedfbody's Avatar
Hey guys
I will be having my motor pulled out of my car today because I will be putting a new heads,cam,intake on it. I have the original heads,rr,lifters,pushrods,and intake sold.so it will be sitting as a bare block(no top half of motor) As of right now I will not be able to take motor to my engine builder for a couple of weeks, the motor will be in my shed for about a month, it's not very insulated. is there any suggestions about storing this.
Thanks Phil
Old Oct 6, 2011 | 11:42 AM
NastyBuzzard's Avatar
Re: Engine storing suggestions or recommendations
Just oil the cylinders and what ever else you think has potential for surface rust. Then put a big trash bag over it and tie it up that will help for moisture too.
Old Oct 6, 2011 | 11:57 AM
RamAir95TA's Avatar
If you can, pick up an engine storage bag (they're super cheap). A trash bag is far too thin to provide ample protection from the elements. You want it airtight. This is an instance where EVERYTHING should be coated in oil.
Old Oct 6, 2011 | 02:33 PM
Where would I get the engine cover from. I am assuming just use straight engine oil wipe down cylinders and top of pistons?
ChrisFrez
Jan 11, 2015 03:47 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
nballisru
Dec 14, 2014 05:01 PM
Dec 1, 2014 08:08 AM
