Engine is on stand, oil priming not coming thru push rods.
Old May 8, 2005 | 10:37 AM
BlackDog's Avatar
I got the engine on the stand and I'm priming the oil pump before putting on the intake. I hooked up a gauge and I'm getting 50psi. I'm not getting any oil coming thru the push rods. I have roller lifters and rockers. I thought that I should see oil coming thru the push rods?
I'm using a drill and have rotated the engine a couple of times while priming.
Any ideas before I button up the motor?
Old May 8, 2005 | 11:18 AM
EviLZ28's Avatar
Re: Engine is on stand, oil priming not coming thru push rods.
what kind of priming tool are you using? If your using the tool that is just a skinny shaft that connects from a drill to the pump, then you will not get oil through the push rods. I use a old distributor that I shaved the teeth off of on the gear as if you look your Oil drive assy, You will notice 2 collars on it with a space in the middle. THat is what directs the oil to the camshaft and lifters.
Old May 8, 2005 | 11:53 AM
BlackDog's Avatar
So, it's the coller that pushes the oil to the rods. Ok, that makes me feel better. I was using the long shaft attached to the drill.
Thanks.
Old May 8, 2005 | 12:30 PM
Mystic97Z's Avatar
i did the same thing using an electric drill and a flatblade screw driver, ,, didn't get oil through mypushrods either.
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
