Engine squeak upon cold start
Old Mar 6, 2009 | 09:43 PM
stevedrag's Avatar
My 1997 Camaro has an annoying squeak when it is first started. After a few
minutes of running noise goes away. Anyone else experience this problem?
Suspect idler pulley may need replaced but not 100% sure
Old Mar 7, 2009 | 01:52 AM
mrmint69's Avatar
Mine does it to. I suspect the belt. You could start it with the belt off and see if it goes away.
Old Mar 7, 2009 | 08:00 AM
green.Z's Avatar
I have had this problem more than once, every time a new belt fixed it. Could be the idler though. If you haven't changed the belt in a while, I would just do that and see if it fixes it.
Old Mar 7, 2009 | 08:29 AM
Make sure your water pump has not dripped any coolant on the pulley. You will have to check before startup.
Gtpguy
Jan 26, 2015 04:50 PM
HCz28
Jan 11, 2015 11:21 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
Britbilly
Jan 7, 2015 08:49 PM
jayblev95
Dec 1, 2014 06:55 AM
