Engine sitting for 3 years.
Old Mar 22, 2013 | 11:33 AM
94NDTA's Avatar
Looking for a little advice. 3 years ago I pulled the heads an intake off my lt1' only tear a joint in my shoulder, making me useless for a year, and haven't been able to get to it since. I put some oil on the pistons and the cylinder walls, and wrapped the motor the best I could. Well now is the time to put It back together and start it up.
I will be pulling the tank and doing the fuel pump, cleaning it out. Any steps I should take before starting it up with the new heads and valve train? I have not put anything together yet.
Old Mar 22, 2013 | 01:25 PM
Catmaigne's Avatar
Re: Engine sitting for 3 years.
I'd turn it over a few times by hand, then crank it with the starter motor a few times until you get oil pressure... but that's just me. You should be good to go otherwise. 3 years isn't all that long.
Old Mar 22, 2013 | 06:45 PM
valter's Avatar
Not a big deal, if it turns over you are ok. Mine was sitting close to 6 years with dropped valve in a '97 T/A, head off. Fixed it this year and it's running great.
Old Mar 22, 2013 | 07:10 PM
94NDTA's Avatar
Were your heads and intake off the car like mine?
Old Mar 22, 2013 | 07:17 PM
valter's Avatar
Re: Re: Engine sitting for 3 years.
Yes, intake and one head off.
Old Mar 22, 2013 | 09:53 PM
94NDTA's Avatar
That makes me feel a lot better.
Old Mar 23, 2013 | 06:02 PM
bw_hunter's Avatar
I'd probably rent a priming tool and prime the system without turning over the engine. When oil appears at a few of the rockers, turn the engine over by hand until all of the rocker show oil. Then Bol it back together and enjoy!
Old Mar 26, 2013 | 10:58 AM
94NDTA's Avatar
I'm not sure how I am going to prime it with it still in the car.
Sergio
Jan 27, 2016 04:27 PM
Roadie
Feb 16, 2015 10:34 AM
Alex Barnes
Jan 24, 2015 10:21 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
deadmanrunning
Jan 3, 2015 01:12 PM
