Engine Rocking while cruising
Old Apr 20, 2005 | 01:28 PM
Speedy94Z's Avatar
I hope you guys can help me out. I have a 94 Z28, 77K miles, and its a M6. The car seems fine for the first 3-4 minutes or so, but after that, it feels like the engine starts rocking back and fourth in relation to the car. This happens at any speed and any gear. The key is....it always happens around 1200-2000 RPM while I'm cruising at a constant speed. If the clutch pedal is pushed in, the rocking problem will not occur at all. I just came inside after replacing the trans mount, but that didn't help. Also, the engine seems to make plenty of power. Any ideas would be very helpful. thanks
Old Apr 20, 2005 | 04:05 PM
Speedy94Z's Avatar
Re: Engine Rocking while cruising
Anyone?
Old Apr 20, 2005 | 04:13 PM
BlownF1's Avatar
That's gonna be a tough one without a better description. Could be motor mounts, or something loose, or maybe you're feeling a hesitation/stumble, driveshaft vibration, etc?? Does the motor move abnormally when you rev it in park?
Old Apr 20, 2005 | 04:51 PM
Speedy94Z's Avatar
No it looks fine when its in neutral and the motor is reved. The car only has this problem when it is in gear, and cruising at a constant speed.
Old Apr 20, 2005 | 05:06 PM
ZFan88's Avatar
Sounds like a driveshaft problem. Time to upgrade!
Old Apr 20, 2005 | 05:15 PM
Silver's Avatar
In my experience a vibeshaft will get worse as you increase speed and really doesn't shake until higher rpm's. Perhaps an ignition problem is giving you a stumble at low rpm's. I can't imagine a 'rocking' though. Perhaps a better word is 'vibrating'?
What changed when this started? Anything?
jayblev95
East South Central
Feb 15, 2015 02:26 PM
jayblev95
Jan 6, 2015 11:52 AM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
ChrisFrez
Nov 23, 2014 10:33 AM
