Engine removal & brake line question
Old Oct 28, 2005 | 07:20 PM
Jeff95TA's Avatar
I've been reading for about an hour now after searching....
When dropping the engine from the bottom, some people say just disconnect the brake lines, and some people say remove the whole ABS/master cylinder assembly.
My specific question is, with TCS, can you just disconnect the brake lines? Because it doesn't look like the engine will clear the traction control valve assembly that is below the ABS unit.
Old Oct 29, 2005 | 07:27 AM
Jeff95TA's Avatar
Re: Engine removal & brake line question
I could have just taken it all off instead of spending so much time trying to figure this out, but I'm trying to document all the steps for a writeup.
Anyone with TCS that has done this, I'd appreciate your thoughts. None of the writeups I saw mentioned if it was w/ or w/o TCS.
Old Oct 29, 2005 | 09:12 AM
Jameslt1TA's Avatar
I dont have tcs but i just removed the brake lines and it was kind of a pain...they liked to hang up on things when the engine was being lowered.
Old Jul 9, 2006 | 06:29 PM
Raped Ape's Avatar
Question Re: Engine removal & brake line question
am curious if you found an answer. I'm going to drop mine soon and have tcs on mine.
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
