Engine Rebuild update.
Old Jan 6, 2005 | 08:27 PM
Silvershark's Avatar
Ok, so come August 15th I will have owned my camaro for a year. After about a month of driving my camaro i noticed an oil leak but I could not determine where from. Then after deciding to break down and rebuild the motor I found that the leak was coming from the rear main. I have since been purchasing car parts to do this engine build correctly, but at the same time with a budget.
Below you will find what I have purchased.
Engine Block Parts
Summit Forged Kit
GM847 Camshaft
Sir "I" Beam Rods
Stock Crank Polished
Rear Main Seal
Engine Top End Parts
Coated Intake Manifold
1406 Gaskets - Hooker Headers
160* HyperTech Thermostat
Crome Valve Covers
52mm Throttle Body
OPTI Conversion Parts
Electric Harness
VAC Harness
VAC Fitting
Timing Cover (95) with gaskets
Intake Gaskets
Water Pump Gaskets
95 Cam Timing Gear
Miscellaneous Parts
Hooker Longtubes
I am getting really close to having all the parts required to complete the shortblock rebuild. However I am stuck on a few key components.
What Timing Chain?
I have been reading about the k800 springs... However I thought I saw a website that sells a k800 kit of some sort. Any idea who sells this kit? I am home porting the heads and will be getting the heads checked etc.
Any help would be appreciated!
Thanks.
Sergio
Jan 27, 2016 04:27 PM
transam_388
Mar 15, 2015 11:53 AM
ChrisFrez
Jan 4, 2015 08:43 AM
Not Dave
Dec 11, 2014 06:32 PM
