engine rebuild?
Old Feb 7, 2004 | 12:56 AM
ismokerice's Avatar
engine rebuild?
I have a 94 Z28 with 140k miles on it. I want to do a cam swap but i wonder if I should rebuild my motor first. I feel it getting tired, and I know my lifters are weak. My compression is fine while running and cranking, but I do have some leakdown. I can not afford to fully build a motor right now, so if I did rebuild it, I would want to do it as cheap as possible. Would it be worth it just to disassemble the motor and put new bearings/rings in, or would I have to replace parts and do some machining to it? Also where do you guys get your parts from?
Old Feb 7, 2004 | 06:29 AM
S.J.S.'s Avatar
Well look at it this way. There have been a lot of posts about guys spinning their bearings after a cam swap. A lot of them are motors with high mileage. Soooooo......if you do the swap with 140 on it, odds are you'll probably junk your motor anyway. If I were you I'd wait and rebuild it, and while you're doing it throw in the cam.
Old Feb 7, 2004 | 12:32 PM
96LT14u2Nv's Avatar
a cam swap at that high mileage is definately a risk. it is up to you. i, personally, would prolly rebuild it and do a cam then.
Old Feb 7, 2004 | 12:48 PM
AxeGrinder30thZ's Avatar
Definitely rebuild.
Sergio
Jan 27, 2016 04:27 PM
transam_388
Mar 15, 2015 11:53 AM
Not Dave
Dec 11, 2014 06:32 PM
squirrels
Jul 13, 2002 01:58 AM
