engine question ...please help
Old Jun 20, 2008 | 10:21 AM
ghost stripes's Avatar
i have a lt1 engine and its normally cranked up when the starter spins the first round or so ...but lately it spends 10 or 15 times before cranking is that a sign the opti is going bad?... it still runs but its scaring me...thanks
Old Jun 20, 2008 | 10:28 AM
bombebomb's Avatar
I knew someone with an Iroc whose did this, his was a leaky injector, but thats just a shot in the dark. Im sure someone will be able to help you out.
Old Jun 20, 2008 | 12:43 PM
93transam1234's Avatar
Check the vacumme house that is attached to the fuel presure regulator. If it has gas in it the it is most likely a bad FPR. Could also be a bad part on the fuel pump or like said above a leaky injector.
But to make sure fuel is the problem get a fuel presure gauge and hoo it up to the car, the car should hold a pretty steady presure when primed and then turned off. Report back with that info and it could narrow down the list
Old Jun 20, 2008 | 01:09 PM
brubaker's Avatar
does it do it when hot, cold or all of the time
Old Jun 20, 2008 | 01:28 PM
BUBBA's Avatar
FP might be ready to take a crap. As mentioned, check out the fuel system. JMHO
Old Jun 21, 2008 | 09:37 AM
cold and hot it still cranks the same
Old Jun 22, 2008 | 07:32 AM
Guest47904's Avatar
Guest
Why don't you do the fuel pump prime test, to see if the fuel is flowing back out of the rails toward the tank???? Simply turn KOEO for about 3 seconds and then off. Then repeat this about 6 times. Then on the 7th time, crank the engine over to start it. If it starts up quickly, you have proven the fuel is going back to the tank. This is usually from the defective check ball in the fuel pump unit inside the tank.
You could also see the effect of this with a fuel pressure gage connected to the schrader valve located on the fuel rails. The pressure will drop quickly after shuttin er down. Several owners of Fbods complain about the drop in pressure due to a bad check ball.
If that doesn't help the situation, I would seriously look over the ignition system. Cap, rotor, plugs and wires.
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
ChrisFrez
Nov 23, 2014 10:33 AM
