Engine Question
Old Jan 23, 2006 | 03:54 PM
Z28AP's Avatar
Engine Question
Does anybody know if a chevy 454 engine will fit in a 1995 chevy camaro and if the transmission will bolt up to that engine. Without any major modifications.
Old Jan 23, 2006 | 03:59 PM
FastZinTennessee's Avatar
Re: Engine Question
It will not fit without some major modification.
With that said, I'm sure someone on this site who has a 14" e-****, can install headers on a 4th gen camaro/firebird in 10 minutes (retaining AIR/EGR) and who only dates supermodels will chime in here in a few minutes telling you that it's a pretty simple and straightforward swap.
Old Jan 23, 2006 | 04:06 PM
Z28AP's Avatar
Re: Engine Question
well can a cast iron dfi 98/99 truck engine fit into the 95 camaro. or would it need alot of modification too.
Old Jan 23, 2006 | 04:10 PM
Re: Engine Question
The engine from a 98 will bolt in no problem (and bolt up to the trans), but the 99 will not bolt in and will require some fabrication, or you can just swap subframes from a camaro/firebird that came with an LS1.
Are you planning on using a carb or do you want fuel injection?
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
ChrisFrez
Nov 23, 2014 10:33 AM
