Engine overheating
Old Jul 9, 2007 | 09:18 PM
afkevin_20's Avatar
Engine overheating
I have a 94 Z28. I am experiencing overheating problems. Today I just changed the thermostat and my next option is the water pump. Today after replacing the thermostat, I found out that I have a crack in a hose that comes out of the water pump and it looks like it goes to the air conditioner, does that seem right? Its between the water pump and a T. Could anyone help me find out what kind of part I need to fix this hose. I don't know what type of hose it is. Should I just take it to a Chevy dealers repair shop? Another thing is when I am driving down the road, it starts to sputter or crap out. Any suggestions? I am thinkin I need to change the spark plugs. I checked the oil and the oil is good, no white, so I know I didn't blow a head gasket. Unless someone thinks I did. I also put some fuel injection cleaner in the gas tank to see if that helps. maybe its not getin enough fuel.
please help me,
Kevin Ward
Old Jul 9, 2007 | 09:37 PM
Dawgz83944's Avatar
Check your radiator/reservoir cap. If it can't hold pressure your motor will get hot. Of course if there is any bad hose you'll need to replace that too. Very unlikely (not impossible) that the water pump is bad.
Old Jul 9, 2007 | 09:42 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Are your fans coming on?
Old Jul 10, 2007 | 11:59 AM
afkevin_20's Avatar
ok that will save me money, i found a small crack in a hose that comes out of the water pump that is joined into a T and i think it goes to the AC unit.
Old Jul 10, 2007 | 12:15 PM
BUBBA's Avatar
Checkout Shoe's site for diagrams of your hoses.
Old Jul 11, 2007 | 11:39 PM
afkevin_20's Avatar
What Is The Site
Old Jul 11, 2007 | 11:50 PM
Originally Posted by afkevin_20
What Is The Site
Just look in the sig...
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
