Engine Noise
I have a '95 Z28 with the LT1. It has 117,300 miles and is strong. Being high mileage is the only drawback. I cranked it this morning (temps around 35 and have been much lower) and it began to make a noise like a stuck lifter or valve with popping an snapping from the exhaust. It gradually subsided, but my concern is am I supposing correctly and should I use something like Marvel Mystery Oil to loosen up the internals? What other suggestions can I get?
It is due an oil change. Would this possibly help clear it up?
After daylight I went back out and cranked it again and found something unusual. My wipers were making the noise I heard earlier in the dark (Yes I will admit to my phoopas). The wipers were "off", so I wiggled the wiper switch and they quit moving.
Only thing is, that won't cause the popping and snapping out the exhaust pipe.
It is due an oil change. Would this possibly help clear it up?After daylight I went back out and cranked it again and found something unusual. My wipers were making the noise I heard earlier in the dark (Yes I will admit to my phoopas). The wipers were "off", so I wiggled the wiper switch and they quit moving.
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
