engine missfire need help
Old May 14, 2006 | 02:58 PM
tony_mid's Avatar
I just changed the plugs and wires because it was missfiring before and that seemed to fix it but now(two weeks later) it is missfiring again on the 5-7 cylinders. The O2 sensor went out about a week ago on the driver side but i dont think that would make it do it. Any suggestions are helpful!!
Old May 15, 2006 | 12:49 AM
tony_mid's Avatar
Re: engine missfire need help
c'mon some1 help me out
Old May 15, 2006 | 12:54 AM
HardcoreRM125's Avatar
Actually, if an O2 sensor is bad, it will lean or richen that side too much, and cause it to get bad mileage, run like dick, and miss some. Maybe you got a bad "new o2" sensor?
Old May 16, 2006 | 03:07 PM
tony_mid's Avatar
Yeh i did but i replaced it and now its still is missing mostly on the 7 cyl. which was the opposite side the o2 sensor went out on. some1 told me it might be the "opti" but im not sure wat that is it sounded like it was in the distibutor.
edman
Mar 13, 2015 09:39 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
OneBad98Z
Aug 6, 2002 03:23 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
