Engine Miss at Part Throttle
When I am cruising along about 2K RPM in 5th or 6th gear, my car starts sputtering and missing. It makes the shifter shake up and down. Also, when I am sitting idling for quite a while, I get the SES code, and thought maybe it was an oxygen sensor. You guys think these two are related?
Re: Engine Miss at Part Throttle
Have you cleaned your TB? Pull it out and have a look. Also check your egr valve. When you go WOT does it pull strong or miss? If it doesnt miss at WOT its not plug and wires. Process of elimination drive the car and see if it does it anywhere else.
.. The one that i destroyed.. the little white thing (guess thats called and electrode) was loose, you could hear it when you shook the plug and also see it move, it was fine a WOT.. it runs smooth as can be now.
oldschool
Feb 9, 2016 09:21 PM
