Engine locked up. but not siezed. help?
Old Jul 7, 2009 | 02:25 PM
chya's Avatar
My engine shut down a few weeks ago. and wouldnt start again.
i got it home andi can turn the crank a few degrees but not much.
my father said its just locked up some how.
any ideas as to what would cause that?
where should i start in dismantling the engine?
Old Jul 7, 2009 | 03:16 PM
wrd1972's Avatar
First thing to do is pull the spark plugs and determine if there is water in the cylinders by turning it over.
Start there.
Old Jul 7, 2009 | 03:21 PM
rthackwray's Avatar
Then pull the oil pan
Old Jul 7, 2009 | 04:40 PM
chya's Avatar
I can only turn it about 1/8 of a turn or so. not enough to see much
and i took the stater off. but when it was on it wouldnt do anything. it couldnt turn the engine
Old Jul 7, 2009 | 04:43 PM
RUDEDOG's Avatar
Sounds like a broken connecting rod.
Old Jul 7, 2009 | 05:11 PM
chya's Avatar
That would make it not turn very much?
and ehrn the engine died it sounded like i just turned the engine off. no noise or anything. it just died.
Old Jul 8, 2009 | 08:03 AM
RUDEDOG's Avatar
M6 or auto? Make sure its in neutral if it's m6.
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
ro2207
Dec 4, 2014 06:18 PM
