engine light
Old Jun 5, 2003 | 01:39 PM
dan6441's Avatar
engine light
just the other day i started my car up and the little engine light went on. is it time for a tune up or did a sensor go? one of my buddies told me to buy a code reader to check the problem or should i take it in to the dealership?
Old Jun 5, 2003 | 02:12 PM
Blue89Bird's Avatar
you need the computer scanned, dealer is probably 80 for that, autozone is free, or you could buy a scan tool, but you didnt mention if your obd1 or obd2 so its hard to make a recomendation.
Old Jun 5, 2003 | 03:16 PM
Dave88LX's Avatar
Ditto...go to Vato Zone...they'll pull it for free.
Old Jun 5, 2003 | 04:09 PM
Re: engine light
You might want to include the year of your car when you post a tech question like this, because not all LT1's are the same... Big difference between scanning an OBD-II (AutoZone will do it) with 100's of trouble codes, and scanning an OBD-I (not all AutoZones will/can do it) with the much simpler diagnostics. Even within the OBD-I models, there are differences between the 93, 94 and 95's that can alter the answer.
I guess the simple answer is "don't guess, get it scanned". But unless you have a 93, you can't use the cheapie "code scanners", or use the paperclip to short out the ALDL pins.
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
Jul 4, 2005 05:00 PM
