Engine Lagging, rpms drop from 900 to 4-500
Old Jun 5, 2006 | 12:12 PM
  #16
Gripenfelter's Avatar
Re: Engine Lagging, rpms drop from 900 to 4-500
Originally Posted by live4therush
No it shouldnt be the opti, i just replaced the opti, coil, ignition module, plugs, wires, and map sensor about 6-7000 miles ago. so im thinking it cant be anyone of those. Dont think its runnin rich, not that i can notice anyways. When the opti is goin it will throw codes and mine isnt throwin any.
Doesn't mean anything. Electrical items can pop at any time.
I had an opti go bad on me last year. Replaced it with a brand new one from GM. The new one lasted a week before it started dying. Replaced it again under warranty...next one was a DOA.
I've swapped over 10 optis over the years on friend's cars. They can last 60,000 miles or be DOA.
If the car is running rich, I would check ignition and fuel psi.
If there is no black smoke or scanner doesn't show high mV, then go with Injuneer's recommendation.
Old Jun 8, 2006 | 01:31 AM
  #17
95BlackTA's Avatar
Did this ever improve when you replaced the IAC(if you ever did?)
Old Jun 8, 2006 | 05:02 AM
  #18
97trans's Avatar
I had the samething happen to my car. When was the last time you changed your fuel filter. I changed the filter and it went away. maybe its something simple
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
97SSdude
Dec 31, 2014 07:43 PM
centric
Aug 15, 2002 09:04 PM
