engine knocking!
Old Jul 28, 2008 | 03:12 PM
whiteLT1's Avatar
engine knocking!
i was driving the car today and when i got back home i noticed the engine was knocking, i checked the oil and it was fine! i was thinking it was a rod but im not sure. it does it all of the time now at any rpm. if anyone could help with this i would appreciate.
Old Jul 28, 2008 | 03:19 PM
'94 Bad A Z28's Avatar
Could be a rod bearing, maybe you can get us a video of this knocking? Moving the camera all around the motor so we can try to tell where it is coming from.
Old Jul 28, 2008 | 03:34 PM
BUBBA's Avatar
You checked the oil level or the oil pressure? I would advise against running it until you determine the problem---no point in making matters worse.
Old Jul 28, 2008 | 03:59 PM
Maverick_997's Avatar
just throwin it out their cuz it happened to me but possible loose rocker or maybe it came all the way off and your lifter is hittin the valve cover
Old Jul 28, 2008 | 04:42 PM
whiteLT1's Avatar
oil level and pressure is fine, i had a couple people look at it and one said the rod and another said something about the rockers
Old Jul 28, 2008 | 08:32 PM
mad95z's Avatar
I would pull the valve covers and check the rockers.
Old Jul 29, 2008 | 12:55 AM
krillformula's Avatar
I broke a valvespring and it was knocking as hell, thought it was a rod bearing. So it could be something in the valvetrain.
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
Lions3
Apr 11, 2003 10:55 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
