engine knock? please HELP!
Old Jan 30, 2007 | 06:30 PM
06lingenfelter's Avatar
could it be a rod bearing or main bearing? its not the lifters or rockers. they are brend new. is there an easy way to find an ENGINE KNOCK. what about unplugging the spark plug till the knock goes away. and thats my messed up bearing.
Old Jan 31, 2007 | 01:28 PM
gee, thanks for the help guys!
Old Jan 31, 2007 | 01:32 PM
Chris 96 WS6's Avatar
Yes it could be several things. You sure it is a knock and not a ping?
Not sure how unplugging the spark plug is going to help at all. If a rod or main bearing is bad it will only continue to get worse the more you run the motor.
There's no way to fix that w/o taking the motor apart.
If you are talking about pinging, then that's a whole different issue.
Basically we need more information before we can help you.
Old Mar 9, 2007 | 04:07 PM
i took the oil pan off and the rod bearing i thought i spun isn't spun. any suggestions now? i hope it isnt a main bearing because i have replaced my whole entire valve train w/ the lt4 hot cam kit. including new lifters and hardened pushrods. i hope its a dif. bearing cause holy crap if i have to take apart the rest of my motor again im going to be pissed. any similar problems, please tell me what happened.
Old Mar 9, 2007 | 04:08 PM
ttt
Old Mar 9, 2007 | 04:20 PM
arcticz28the383's Avatar
If you still have the oil pan off, make sure you try to move all the rods around just to make sure they're all ok. Also look at the sides of the cylinder walls for vertical scraping, this can indicate severe piston slap or a worn out wrist pin. Is there metal shavings in the oil, shiny like a bearing surface? I also suggest you readjust your valvetrain and make sure you do it properly, use the search on this site. If that doesnt help you should inspect your lifters to make sure they're all ok. And check for exhaust leaks or exhaust rattle, which can sound like a knock sometimes.
Old Mar 9, 2007 | 06:08 PM
WrathGrape's Avatar
Among other things, if the engine knock is detonation, it can be caused by some bad gas. If your octane isn't good, it's possible that you could be experiencing detonation. Fluctuating temperatures can cause condensation in the gas tank, leading to this poor octane rating.
Old Mar 10, 2007 | 08:02 AM
95Blackhawk's Avatar
Use a stethoscope. Very interesting what you pick up when you start using it and learn what the different sounds are.
Unfortunately, this is when it is running you do this.
Old Mar 10, 2007 | 09:52 AM
transAMdriv3r's Avatar
If its anyhelp, here is a video of a rod knock http://videos.camaroz28.com/search/r...a3c40d03e8.htm
Old Mar 10, 2007 | 11:44 AM
Wow
thats what it sounfds like. how do i fix that problem. what did you do? i have replace the lifters, pushrods, rocker arms, springs, cam, those arent making noise i thought it was a bad lifter so i decided to replace everything. well i started the car and the knock was still there. how do i fix the problem.
Old Mar 10, 2007 | 11:56 AM
SnakeSkinner28's Avatar
How does the car run? Its possible to have overtightened the rocker arms.
Old Mar 10, 2007 | 01:28 PM
ok heres the deal its not the rocker arms period. if you watch the video above that is what it sounds like. i had the knock with all the stock componets so its def. not the rockers or lifters or an exhaust leak. its def lower end. i think its rod knock. i thought it was a spun beraring. could it be a wrist pin? the car runs fine it just has a real loud knock not a tic.
Old Mar 10, 2007 | 01:29 PM
still need suggestions as of 3/10/06 1:30 pm.
Old Mar 10, 2007 | 03:58 PM
ok i found out that it is the number 8 cylinder with the problem. when i went to take the rod bearing off, the rod was real loose on the crank. do you think i may have damaged the crank?
Old Mar 10, 2007 | 06:18 PM
thats exactly what was wrong with my t/a. I had spun number 8 too. I it remember just like yesterday, scarry
sorry for the bad news
