Engine Ballancer/ Pulley - Does it matter how it lines up ?
Old Jun 29, 2003 | 10:45 AM
Van5150's Avatar
Please dont laugh, I see the arrow on the pulley, but do not see any markings on the hub. Does it matter which way it goes on., ?
Old Jun 29, 2003 | 10:48 AM
CANTONRACER's Avatar
No.
Old Jun 29, 2003 | 10:54 AM
notstock4long's Avatar
I wasn't sure if it did, but when I put mine on there was a bump on one side, so I figured if it mattered thats where it would probably go.
Old Jun 29, 2003 | 10:56 AM
Yes, it matters, because the pulley can only go on one way. The spokes are not symmetrical. The arrow on the pulley will match a line that is embossed on hub.
Old Jun 29, 2003 | 11:04 AM
There is no key way for the hub to locked into place. It is not uncommon for the entire hub assembly to rotate. So, yes, you can line your pulley up with the hub, but the chances are your hub is not lined up correctly, so does it matter if the pulley is?
Old Jun 29, 2003 | 11:22 AM
Dude, the pulley can go on the hub only one way.
Old Jun 29, 2003 | 11:37 AM
TA Dreaming's Avatar
i think hes asking if the hub/balancer assembly goes on the crank a certain way. its my understanding that technically it doesnt matter since the hub/balancer assembly is neutral balanced, but that its a good idea to mark the crank and hub so that you put them on the same way they came off. correct me if im wrong please. Trey
Old Jun 29, 2003 | 11:40 AM
Van5150's Avatar
Wow everyone is up early today. Thankyou all for the correct answer = No / Only goes on one way. Have fun today, nice here in Hew Hampshire, but I am sure it will rain soon, being the weekend and all its has to rain. lol
Old Jun 29, 2003 | 11:49 AM
Hard to say if the hub is off or not.
If the pulley has any weights in the holes in the perimeter (some do), the hub must be put on the same way it cam off or you will get vibes.
Old Jun 29, 2003 | 11:52 AM
ok cool. i was mistaken thanks for clearing that up. Trey
Old Jun 29, 2003 | 12:31 PM
Van5150's Avatar
Hub was not off, and it did only go on one way, thanks again.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
