Energy Suspention motor mounts
Old Apr 4, 2008 | 12:30 AM
mad95z's Avatar
Having a FUN time with these poly mounts.
The 5 inch bolt that runs through the passenger side mount would not go through. Too small of a hole. Had to pull the mount out. Even with the mount out of the car the hole in the mount is to small for the 5 inch stock bolt to fit through. damaged a little of the poly in the bolt hole during the battle.
I guess i may need to drill out some of the poly in the hole, or hammer the bolt through a couple of times before re-installing. I had no trouble with the drver side. Lets just say a few 4 letter words were yelled out in the attempt. This is why I love cars! Anyone have this experience?
BTW 95 LT1 maro
Old Apr 4, 2008 | 12:46 AM
GreasyB's Avatar
Bigger hammer?
Old Apr 4, 2008 | 01:02 AM
mad95z's Avatar
Can't fit bigger hammer in the engine bay..... Was thinking TNT!
Old Apr 4, 2008 | 01:57 AM
ssbowtie1's Avatar
Keep us updated on the install. I have a set of prothane mounts waiting to go in.
Old Apr 4, 2008 | 02:38 AM
94zgreenmachine's Avatar
BTW 95 LT1 maro
I have these same mounts but no problems. I just pulled my motor and I was able to pull the bolts out by hand, after I took pressure off the mounts by raising the engine hoiost.
Strange yours are giving you some grief. Does the hole appear to be egg shaped or otherwise deformed?
Old Apr 4, 2008 | 03:47 PM
TobyZ28's Avatar
My mechanic had a bit of a bitch with them intially too
Old Apr 4, 2008 | 04:28 PM
Vicious95Z28's Avatar
I had both of my Prothanes installed in about 3 hrs but I farted around at the shop some too.
Old Apr 5, 2008 | 11:14 AM
Another Red Z's Avatar
I used the Energy Suspension mounts. I had to run a drill through them to make the bolt fit.
Old Apr 5, 2008 | 12:28 PM
caldercay's Avatar
[snipped]
If at all possible, return them for the Prothanes. Mine fit perfectly
with no issues concerning fitment, bolts, bolt holes, etc. I bought the
"3-pack" - engine and tranny mount.
Old Apr 5, 2008 | 12:30 PM
dangalla's Avatar
yeah mine were simple as well
Old Apr 5, 2008 | 12:33 PM
mad95z's Avatar
Well I got them installed last night. I had to run a drill but through the passenger side mount a couple of times. It helps to put a little dish soap on the mount so it can slide in the clamshell when you try to line up the
5" connector bolt.
I found it useful to leave all the mounting bolts loose untill you get the large connector bolt through. Also start with the passenger side, once thats in leave all the bolts loose and install the drivers side mount, you will have to move the jack up or down to find the right engine height.
When done, don't forget to tighten everything up good!
Old Apr 7, 2008 | 07:30 PM
95zsean's Avatar
I just had the same problem on Sunday!!!!!! Drilled it out some to get the excess poly out af the bushing in the center. ***##*****###!!!!!! Wish i would have done a search BEFORE i tryed to install them!!!!!!
Old Apr 9, 2008 | 02:32 PM
DAVE00's Avatar
Same problem here when I decided to change the mounts out while I was pulling the pan to replace the gasket. I ended up getting it all installed and done, but had to leave the mounts loose from the block to get the bolts in and then tightend up the mounts and worked like a charm. Glad to hear you finally got it solved. Some times I hate working on these cars, but then I drive her on the weekend and all is forgiven.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
May 25, 2015 09:35 PM
Rde Bandit
Mar 21, 2015 10:17 PM
Nostang 96z
Aug 31, 2002 12:01 PM
x7x7
Aug 15, 2002 06:49 PM
