Emmisions Legal Headers for a '95
I've been looking for some nice headers for my '95. The catch is, I have to pass the sniffer test anually. This seems to slim my choices considerably. I was looking into the MAC headers, but they seem kinda cheap. Id rather spend a little more and get a nicer set of headers if possible. What is my best choice? Most of what I've seen on the board consists of people with off-road set ups.
I looked into long tubes, but no one makes an emmisions legal set up do they? I've seen the dual cat set ups for the LS1s, but with a single cat car I cant even think of how that is possible. Can I retrofit to a dual cat 96-97 set up and run long tubes?
Basically I want the most power I can get at the best price possible. Any suggestions? I'm a poor college kid who invests all of his money into his car, so dont break the bank too bad.
Originally posted by 95z28 -quicksilver
AS&M mids. They pass with a functional cat.
Chris
Chris
Spending that much will definately set me back. It may be worth it though.
Originally posted by 2CNTRY
You may still go with LTs. Most shops don't care about the visual, which you would otherwise fail. All they are concerned with is passing the sniffer. You should be able to pass the sniffer with LTs no problem or the worst case scenario would be that you would have to get a PCMforless tune for 99 bucks. You should pass the sniffer though with the LTs. Try the new Jet-Hot LTs at about 500ish.
Also, would I be able to do this tune myself, or would I have to find a shop? I know you can order the program, but I'm assuming you'd need soem type of knowledge to properly tune the car.
Re: Emmisions Legal Headers for a '95
http://www.thunderracing.com/index.c...ategoryid=1052
Originally posted by FastZinTennessee
My car passed the sniffer without a catalytic converter. Passing visual is another thing entirely though.
John
John
That's what I was gonna do. I ended up having a buddy pull some strings at the emmissions place
Next year I'm gonna have to gut a converter, cut it in half and put it on my exhaust.
John
Next year I'm gonna have to gut a converter, cut it in half and put it on my exhaust.John
From: Austin, TX or Texas State University at San Marcos
You could always put a cutout before the cat and just cap it up when you get it inspected. Thats what i do. Got my car inspected on saturday..............works everytime.
Chris
Chris
OK guys, now I'm thinking Hooker LT's, with a mufflex Y-pipe. I'll have to save a little bit more but it should be worth it. Now, heres a question. If I decided to put a cat on after the Y-pipe- would it be too far away from the motor to get hot? I'm not exactly sure how different the exhaust set up would be with the long tube set up.
To make an "off road" pipe with the cat still attached, all that you have to do is cut the 2 1/2" ends off far enough to fit a 3" pip through, gut the cat, and then weld in the 3" straight pipe. That will pass the visual and you will still have an off raod pipe that you don't have to swap with a cat every time you get tested.
I'd get them over SLP any day.
