Emissions in the state of georgia... Some help plz
Old Apr 23, 2003 | 11:46 AM
radd2983's Avatar
Georgia is just great except for thier new way of giving emissions. They hook up the car computer and read the error codes. not good for me =(.
I was woundering if u guys could recomend some ideas on ways around these errors
P0122 Throttle/pedal position sensor/Switch A circuit Low input << do not know much about this one. i cut off the throttel stopper so i can get wide open throttle could that cause this?
P0410 Sec. Air injection System malfunction << I have the whole K&N intake system could it cause this error
P0420/430 Catalyst system efficiency below Threshold (bank 1 &2) << i know what causes this one. i have full exhaust no cats ect. Looking for a way around this what can i do?
Old Apr 23, 2003 | 12:22 PM
ZZtop's Avatar
"I cut off the throttel stopper so i can get wide open throttle.."
Are you saying that a Camaro will not go WOT without removing some throttle stopper? I have never heard this before. Is this true? I cant imagine GM would build a car that cant go full throttle
Old Apr 23, 2003 | 02:16 PM
radd2983's Avatar
well
it restricts wide open throlle a hair. Its a decent and free mod so why not?.... i was not looking for this kind of responce but what can i expect.
Any one want to reply to my post with helpfull info?
Old Apr 23, 2003 | 03:06 PM
ZZtop's Avatar
I ment no offense man, I just never heard that before. The rolling eyes was for GM, not you. Hope someone helps you, I cant.
Old Apr 23, 2003 | 08:49 PM
radd2983's Avatar
Some 1 awnser my post! plz plz plz
Old Apr 23, 2003 | 09:13 PM
will62085's Avatar
when my 3rd gen wouldnt pass, i registered it to my freinds address in white county...no emmissions up there...mabye take out a P.O. box so u can have a valid address...only bad thing, the 2 hour drive to the white county DOT...where in GA do u live?
Old Apr 24, 2003 | 12:42 AM
radd2983's Avatar
i am considering registering it in Jasper, Ga no emmison req there and its only a hour drive. Thanks for the reply know anything about the error codes?
Old Apr 24, 2003 | 12:46 AM
smokindastangs's Avatar
if you find a way to register in jasper....lemme know and i will join ya!
Old Apr 26, 2003 | 10:44 AM
radd2983's Avatar
i registered my car in jasper yesturday. tag was even 40 dollars cheaper than it was in cheroke. my dad lives up in jasper so i used his adress. i am not sure if a po box would work there but, u could find a house they are building and use that adress. when i changed my adress there where no questions asked. good luck.
where in georgia do u live if u do not mind telling me?
Old Apr 27, 2003 | 12:26 PM
i am from marietta ga. Anyone know if a PO box will work?
Old Sep 9, 2003 | 11:38 AM
bad96firechikin's Avatar
P.O. Box will not work, tried today. Someone help me
Old Sep 12, 2003 | 11:16 AM
radd2983's Avatar
LT1 Edit =)
Old Sep 12, 2003 | 11:45 AM
i387's Avatar
Re: Emissions in the state of georgia... Some help plz
The AIR injection system is the system that pumps fresh air into the exhaust manifolds to help heat the cats up faster. I don't think it would have to do with your K&N.
Old Sep 12, 2003 | 12:40 PM
gb95zconv's Avatar
O2 sims should get rid of the cat code. There should be a risistor that you can plug into the AIR to take care of that (do a search to find the value you need). The mod you did to the TB may have allowed the TPS to go out of range.....pull the pcm fuse or dissconct the battery to reset the pcm and dont go wot before testing....
Old Sep 12, 2003 | 12:41 PM
doodad's Avatar
I had the K&N and the GM cold air and never threw code. I also have long tubes, no cats and threw EGR code not AIR. Eliminated the code with LT1edit and can pass emissions now, if I smile and wave $ when they look for the cats. Don't know about the TP dealie.
blac94Z
Nov 4, 2015 01:59 PM
n2oblkz
Oct 12, 2015 01:53 AM
drt
Sep 27, 2015 04:39 PM
Sep 18, 2015 03:46 PM
colts0455
Sep 11, 2015 06:16 PM
