Emissions - Bad Numbers **Please Help**
Old Feb 9, 2005 | 08:38 AM
Marc95z28ConvM6's Avatar
Background:
1995 Z28 6Spd Conv
Original / Stock
162,000 Miles
Opti -Replaced 120,000
No Codes
No Smoke
Mobil One Oil Change 160,000
New Plugs
New O2 Sensors
New Air Filter
Techron Cleaner
1/4 Tank of Gas
E-Test
Target: (gpm)
HC 1
CO 20
NOX 2.2
CO2 N/A
Results - Original Test FAIL
HC 2.27
CO 39.1
NOX 4.1
CO2 464
Results - Retest #1 FAIL (New Air Cleaner)
HC 2.97
CO 31.5
NOX 2.2 (passed)
CO2 348
Results - Retest #2 FAIL (New AC/Delco Plugs)
HC 3.2
CO 34.9
NOX 2.7
CO2 388
Results - Retest #3 FAIL (New A/C Delco O2 Sensors-2)
HC 3.4
CO 43
NOX 2.6
CO2 403
Things are getting worse. Any suggestions?
Old Feb 9, 2005 | 09:30 AM
fesgali's Avatar
Re: Emissions - Bad Numbers **Please Help**
What mods do you have?
Old Feb 9, 2005 | 09:54 AM
Stock
Old Feb 9, 2005 | 10:37 AM
valter's Avatar
Exessive NOX comes from running leaner then normal. Making it run more rich will bump CO and HC. Try cleaning your MAF. Run 20-30 miles on highway just before test on best gas you can find. Drive to different inspection station - away from big cities.
Old Feb 9, 2005 | 10:38 AM
BlownF1's Avatar
The only major thing left that has a direct impact that I can think of would be the catalytic converter. You might consider trying the gallon of denatured alcohol trick...
Old Feb 9, 2005 | 11:11 AM
MAF Cleaned
Smallest Town Around
CAT - Replacement (Brand Suggestions?) Less Restrictive
"You might consider trying the gallon of denatured alcohol trick" That's a new one to me. Is it pour a gallon in the tank? Anyone had it work for them?
Old Feb 9, 2005 | 04:29 PM
I always thought a "punched" worn out CAT would affect CO not all three.
Any other ideas?
Old Feb 9, 2005 | 05:17 PM
FastZinTennessee's Avatar
For reference I passed the emmissions test here no problem with no AIR, no EGR and a straight pipe in place of the catalytic converter. It looks like they measure it differently here but the limit of hydrocarbons (HC) was 220 ppm. I had less than half the allowable.
Any stumbling, hesitation or anything out of the ordinary? I used to drive the car really hard on the way to the testing station to get it nice and hot, it probably didn't do much, I guess it was more for my peace of mind.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
dale3in98
Feb 14, 2015 12:18 PM
