Emissions
Old Feb 26, 2004 | 10:47 PM
Jeremy_30th's Avatar
Emissions
cnc fully ported heads & intake
moroso cai..
lt-4 hot cam
comp pro magnum 1.6 rr
ferra valves
chrome moly push rods
lt-4 extreme duty timing set
hooker long tubes
duel random tech cats
had the car dyno tuned so all the egr air stuff has been deleted as well as the after cat o2 sensors.. many have told me no problem considering its a 97 obd2 and only subject to a scan for trouble codes.. please all opinions and comments are appreciated
Old Feb 26, 2004 | 10:55 PM
Zack's Avatar
are you asking if you will pass emissions?
Old Feb 26, 2004 | 11:01 PM
97WS6SCharged's Avatar
Passing visual would be kinda iffy (depends on what kind of mood the inspector is in). Getting past the sniffer is no problem as long as you've got a good tune.
Old Feb 26, 2004 | 11:18 PM
i have had the test before the mods and all they did was check for a cat and plug into to the computer to check for codes.. and yes your opinion if i will pass or not whould be appreciated
Old Feb 26, 2004 | 11:22 PM
Zack's Avatar
well, depending on how strict they are, youve relocated the cats, a big no no, and dont have the EGR
turbo_Z's Avatar
you should be fine.
Old Feb 26, 2004 | 11:30 PM
THANKS GUYS DOES ANYONE ELSE HAVE INPUT OR SETUP SIMULAR AND PASSED ?
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
