Emgine Removal Questions....
Decided to go through the bottom with this one. Ran into one snag, what to do with the break lines? Where should I unhook them from?
Thats all for now...help if you can.
Re: Emgine Removal Questions....
unhook them from the ABS block if it has one, if not, from the prop valve, it will just be a regular bleed afterwards, no need to worry about the ABS, it wont need any special bleeding
Out the top and ya wouldn't have all that brain damage. (JOKE)
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
