electronic spark control ?
Old Jul 17, 2003 | 05:36 PM
t-trimz28's Avatar
I'm getting trouble code 43 ESC low voltage. Would this be low voltage to the knock sensor or what?
What is the solution?
Chris
Old Jul 17, 2003 | 06:10 PM
May be a problem with the knock sensor or the wire to it.
With the connector off the KS, check for 5v on the harness terminal with key ON. Continue if that is good.
Key OFF. Connector off. Measure the resistance between the KS terminal and ground. Resistance should be between 3300-4500 ohms. If it is not, the sensor is faulty or the sensor is not making good contact with the block.
If all that is good, it might be the knock module or faulty pcm.
Old Jul 18, 2003 | 09:25 AM
t-trimz28's Avatar
Thanks for the reply. I'll post the results.
Chris
May 21, 2015 01:04 PM
Chet1185
Apr 26, 2015 04:07 AM
NewsBot
Apr 20, 2015 03:00 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
