electrical term question
Old Feb 12, 2004 | 08:34 PM
kevmor99's Avatar
I'm looking at this solenoid to use as a battery disconnect (theft deterrent), they rate it for 110 amps continuous ("carry only") and 25 amps make and 25 amps break. I want it to be continuous, but does 25 amps make/break mean the load on it when switching it on and off can only be 25, and once its activated it can go up to 110? Is this just to prevent a 110 amp arc when switching or what?
Old Feb 13, 2004 | 11:15 AM
97FormulaWS-6's Avatar
I believe there talking about how much current it takes to engage/dis-engage the relay/solenid. The Solenoid will draw 25 amps of current when it is engaged... atleast that's what I think...
Look on Parts Express.com I believe and they have a 200 amp continous that only takes an amp to trigger. I've been running it for about 3 years now for my stereo and it works great. They have smaller ones as well, but I always oversize things like that.
Old Feb 13, 2004 | 12:00 PM
Tair's Avatar
I agree, I think the maximum amps the solenoid can handle is 110 amps. The solenoid draws 25 amps when it activates.
Old Feb 13, 2004 | 12:55 PM
Serene's Avatar
25 amps make/break is the max amperage it can disconnect under load. If you try to break the circuit with a load of 30A on the switch, the switch will arc internally and the circuit will stay closed.
110 amps is the maximum amperage it can take when closed.
Basically you should be fine unless you have a huge load on the battery when you are switching this solenoid.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
NewsBot
Feb 26, 2015 02:10 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Moshbmx1
Feb 17, 2015 10:51 AM
