electrical
Old Apr 4, 2013 | 11:26 PM
Chet1185's Avatar
electrical
Not sure if this is the right section but in having a few issues.
Yellow wire at stereo for 12 volt constant has no power, lights on rear view mirror don't work, trunk release doesn't work.
Posted from Camaroz28.com App for Android
Old Apr 5, 2013 | 01:14 AM
slick1hunting's Avatar
I know on mine the trunk release is not fused in the fuse panel at door. It may have a fusable link by battery area as pulling the power wire off battery connection cuts power( the one that goes to fender).
Old Apr 5, 2013 | 09:04 PM
Chet1185's Avatar
Any ideas?
Old Apr 7, 2013 | 03:15 AM
Chet1185's Avatar
How do I test the 12 volt constant?
Old Apr 7, 2013 | 09:21 AM
Zfbod94's Avatar
Re: electrical
I would think the best way would to be test for continuity. A simple ohm test will tell you if there is a break in the wire. Finding the break will be the fun part.
Old Apr 7, 2013 | 07:25 PM
parkers Z28's Avatar
Re: electrical
Check the ground wire on the trunk latch ??
what position was the key set when you were checking for power ??
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
