Electric waterpump.. Pro's & con's???
Old Nov 10, 2011 | 07:09 AM
bencher's Avatar
What are some benefits to an electric waterpump, and also what would be some negatives to having one?? I am having one installed on my car, i understand it is more efficient(pro) but at same time, if im out of town and it goes out, you cant just go to the local auto parts place and get parts for it.(con)
Old Nov 10, 2011 | 07:29 AM
RamAir95TA's Avatar
Re: Electric waterpump.. Pro's & con's???
Pros -
Frees up dyno-proven 6-8HP.
Allows use of a double roller timing chain.
Can run the pump with the engine off for added cooling.
Provides more coolant flow/capacity at lower RPMs/idle.
Eliminates possible leaks from the OEM water pump drive seal.
Relieves some stresses off of the front cam bearing.
Eliminates the water pump drive gear/mechanism which have been known to fail.
Cons -
Can go bad without warning, although the motors are fairly reliable (warning systems available).
Flows less than stock at high RPMs.
Reduced space between the radiator and engine.
Old Nov 10, 2011 | 07:54 AM
bencher's Avatar
Thats a lot of pro's. Looks like I actually made a good decision.
Old Nov 10, 2011 | 08:34 AM
RamAir95TA's Avatar
The big negative for running one to some people is more important than all of the positives. Personally I've been running an EWP since 2004 - same CSR pump.
Old Nov 10, 2011 | 10:33 AM
Guest47904's Avatar
Guest
One other con can be poor electrical connections leading to the pump stops working. Either poor install, failure of electrical connections for various reasons.
Old Nov 12, 2011 | 01:47 PM
Stl94LT1's Avatar
Biggest con: If an e. pump dies, you are dead on the road. A mechanical pump will give you warning before it quits.
Old Nov 12, 2011 | 05:03 PM
lt1-xjs's Avatar
EWP's also give you warning. My first one lasted 4 1/2 years (24k). It made noise for 2 weeks before it even blew the fuse.
Old Nov 12, 2011 | 05:31 PM
Stl94LT1's Avatar
My Mezeire died without warning. I've seen stock waterpumps with the bearings shot and would still cool the car enough to drive.
Old Nov 13, 2011 | 05:47 PM
maybe2fast's Avatar
I am working on a way that will turn on the ses light if the fuse blows...using the AIR circuit (relay, fuse, wiring)
buttercup is the founder it appears
Old Nov 16, 2011 | 01:55 AM
kwik_ta's Avatar
Damn... I bought mine based on your recommendation and plan on one for the ss very soon. I've been pleased with mine so far.
Old Nov 17, 2011 | 09:15 AM
Stl94LT1's Avatar
I should have stated it was an electrical issue, and I'm still running the pump. But, my point was if there is an issue with an electric pump, it will be minutes before you have to shut the car down. It can takes months for a mechanical pump to finally die once the weep hole starts to leak.
Old Nov 17, 2011 | 02:07 PM
ChrisLS1Bird's Avatar
These things are dangerous. I think every EWP installation should include a nice big warning light or buzzer for even minimal engine overheating. If a wire pulls loose or a fuse blows, you better shut it down fast or you will have significant and expensive engine damage.
The EWP wiring on my 383 LT1 was shoddy, the pump shut off, the engine overheated, the head gaskets blew, and water ended up in my oil. Now there are metal shavings in the oil. Expensive mod if you're not very careful.
Old Nov 17, 2011 | 04:30 PM
NJ-LE's Avatar
It's shameful that gm engineers didn't have enough sense to tie the 'check gauges' light to the seat belt or headlight auible alarms. About the factory water pump ... when the sealed bearing failed on mine (very low mileage, but timewise out of warranty) the bearing seal and shield blew out and I lost a lot of coolant while idling for a few minutes in my driveway. It happens. Whether mechanical or electric, use that cooling system port on your passenger side cylinder head for an alarm buzzer.
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
