Electric waterpump cooling capacity vs stock
Old Jul 19, 2005 | 07:30 PM
speed_demon24's Avatar
I think my opti is shot, so I'm going to replace the waterpump too. I'm going to road race my car a few times a year and was wondering if an electric waterpump would be able to handle the extra load, or would I be better off getting another stock pump? And my car is also a daily driver that I drive 6-10K a year too...
Old Jul 20, 2005 | 02:11 PM
Re: Electric waterpump cooling capacity vs stock
Ttt
Old Jul 21, 2005 | 12:24 AM
hvyss's Avatar
I run the Meziere pump. the thing I like is it pumps the same amount of water at idle as it does at WOT. The stock pump flows more as the rpms raise. But still at WOT if flows less the the Meziere. Hope this helps!
HVY SS
Old Jul 21, 2005 | 12:28 AM
fireman's Avatar
You ran a 14.31 completly stock in a GTP?? sounds pretty amazing to me.
Old Jul 21, 2005 | 12:53 AM
HVY SS
Are you sure that even at 6K the mezier pump flows more than the stock mechanical pump?
Old Jul 21, 2005 | 01:00 AM
1. The stock pump is rated to flow 25 gallons per minute at 6000rpm. This means at lower rpm's, it flows much less (especially at idle which is tough on a car in the desert). The Meziere pump flows 35 gallons per minute ALL THE TIME!
I found that on ws6.com. My question is thoug, the meziere pump is rated at free flowing, will it still flow more than the stock pump with the restriction of the coolant system and the factory housing?
Old Jul 21, 2005 | 07:55 AM
snakeatinZ's Avatar
I cant awnser that question, but I can tell you, everyone with a Electric wp needs to buy a watch dog warning light. this light will go off if the coolant reaches whatever temp you set it at. I had a fuse blow to my E.w.p. and it cost me $500.00 to fix my warped heads
P.s. go with CSI same thing, cheaper, easier to modify the stock housing!!$135.00 at thunderacing.com
Old Jul 21, 2005 | 08:06 AM
89385formula's Avatar
The meziere is rated at 43 GPM, the stocker maxes out at 25 GPM, the CSI is rated at 30-37 GPM, and the HD Meziere is rated at 55GPM. Yes it will handle the load, yes its better than stock. And for all the Nay-Sayer's out there...if you are so worried about the pump failing, then spend the $80 or whatever to get the kit this moniters the water pump so if it fails you can pull over and save your heads from warping. Duh, even with the additional cost the EWP swap is a great value, better cooling, about 9RWHP, and it lasts better than the junk stock pumps.
Old Jul 21, 2005 | 12:15 PM
Where can I buy the kit to monitor the pump?
Old Jul 21, 2005 | 02:58 PM
JONEZ_Z's Avatar
Im not finding the CSR at thunderacing. Does anyone know the cheapest place for this pump? Mine is fried and i need another one. Thanks
Old Jul 21, 2005 | 03:09 PM
I have only seen the CSR that cheap in GP's. I think the best price I found was at Buyenspeed racing in the supporting vendors. They have free shipping as well.
Old Jul 22, 2005 | 07:22 AM
snakeatinZ's Avatar
CSR????????? It is CSI performance products Water pump!!! 135.00 Summitracing.com or thunderacing.com
Old Jul 22, 2005 | 09:23 AM
Not any more...they are now CSR perfromance...and I have yet to find any that price except in GP's...look around.
Kyle
Old Jul 22, 2005 | 09:26 AM
besz28's Avatar
try scoggins dickey
Old Jul 22, 2005 | 09:28 AM
blackztpi's Avatar
where do u get the kit to moniter it? it seems to me like if you watch your temp guage, you'll be fine. if it starts to go up increasingly, shut it off.??
