Electric water pump Question
Old Apr 24, 2006 | 02:40 PM
jfbamf's Avatar
Im installing an Electric water pump this coming weekend, and just thought of a question, Is there a cover that covers the hole that is left when I remove the motor driven waterpump, I would assume this leaves a hole in the block..
Old Apr 24, 2006 | 02:46 PM
speedcrazy's Avatar
Re: Electric water pump Question
I just left the hole in the block, it shouldn't cause any problems. You could get the right size freeze plug and seal it off if u want though.
Old Apr 24, 2006 | 02:56 PM
jfbamf's Avatar
My only concern is getting dirt and things like that into the engine..
Old Apr 24, 2006 | 03:00 PM
v7guy's Avatar
A properly sized freeze plug will work great and is what I see used most often. A search will turn up the relevant info.
Old Apr 24, 2006 | 03:05 PM
speedcrazy's Avatar
it shouldn't be a concern. But if your worried about it just get the freeze plug. cost a couple cents. When i did my install everyone said it didn't matter whether you covered it or not. Just a personal preference i guess. The only thing i see with leaving that hole open is you might get more oil in the timing cover but i dont see that as a problem.
HectorM52
Jul 30, 2017 11:46 AM
BMX Dad
Jan 23, 2015 07:00 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
