Electric water pump install
Old Mar 11, 2005 | 07:17 PM
jcolez28's Avatar
I cant find a thread telling me about the cover gasket. Mine is in really bad shape. The one "how to" I read said to pitch it you dont need it. Do I just use silicone sealer. Thanks. Also it said use 14ga wire. That seems awful thin. Thanks
Old Mar 11, 2005 | 09:06 PM
n2oCamaro's Avatar
Re: Electric water pump install
The pump should come with an o-ring gasket but you can add some RTV for extra insurance. I used 12ga. wire.
Old Mar 11, 2005 | 09:18 PM
dirtybird96's Avatar
I used rtv and it worked great, no leaks.
Old Mar 11, 2005 | 10:08 PM
Birdman7389's Avatar
Thin bead of RTV + o-ring on my CSI, no leaks
Old Mar 12, 2005 | 11:39 AM
slimdawson's Avatar
No rtv + the oring and I have no leaks.
Old Mar 12, 2005 | 12:30 PM
Mindgame's Avatar
You don't need rtv with an o'ring. And to the original question... I wouldn't trust rtv all by its lonesome. You can buy o'ring stock by the foot. Look around locally... if no joy, check McMaster Carr.
-Mindgame
Old Mar 12, 2005 | 01:07 PM
sssalah's Avatar
Why not use the original, you can get it at any dealer i suppose for around 4 bucks. part number is 10128329.
Old Mar 12, 2005 | 07:00 PM
jcolez28's Avatar
Thanks guys, I had not looked at the pump yet but it had a gasket built into it already.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
