Electric water pump-help
Old Jan 7, 2006 | 07:39 PM
LT1 AUSSIE's Avatar
Found my pump to be leaking,undecided which way to go with new replacement pump or electric?
Anyone help with which way to go? Any suggestion greatfully appreciated.
And also where to purchase these from?
Old Jan 7, 2006 | 08:00 PM
Temple's Avatar
Re: Electric water pump-help
Go with electric water pump...Mezeire or CSI. Can do a search and get all you would ever want to know about the whole install and possible gains.
http://www.thunderracing.com/catalog...p&vid=4&pcid=5
http://store.summitracing.com/defaul...=egnsearch.asp
Old Jan 7, 2006 | 08:31 PM
OBE1 95Z28's Avatar
Search function is your friend
http://web.camaross.com/forums/showthread.php?t=415602
Old Jan 7, 2006 | 08:52 PM
SLeePer350's Avatar
absolutely go with electric. i am not even going to explain why, just do it. and if they prematurely break (which they 'supposedly' are known to do) you change it in literally 30 mins in a parking lot. if it sounds like i am speaking from personal experience, its because i am!
and in case you were wondering, yes you will definitely pick up some power gains in the 3k-6k rpm range.
your options:
CSR: requires stock housing modification <---currently using this one
Mezz.: requires stock fan shrouding modification
Old Jan 7, 2006 | 10:07 PM
97formulakid's Avatar
I am 100% satisfied with my CSR unit. The install wasn't too bad at all and only took a little bit of modifying to the WP housing. Nothing a dremel can't fixt.
Old Jan 8, 2006 | 02:23 AM
Sleeper_Z's Avatar
I have the Summit brand pump and it works awsome! All my friends got either the CSR or Mezire and my summit has out lasted them both. Ive had it in for 2 years and put over 20,000 miles on it and my car never gets over the first white line on the gauge and thats even sitting in traffic. I was alittle leery of the summit pump but after living longer than a CSR and a Mezire Im impressed. Ive installed 3 of them since buying mine and all of them are still alive and kicking on daily driven cars. Just thought Id add my $.02
Jeremy
Old Jan 8, 2006 | 05:59 AM
LT1 AUSSIE's Avatar
Thanks for the replies, and coments I have read all the posts in the links, have looked at all prices and sims to be about 3 electric wp on the market, Iam looking at the Sumite ewp, and i like the price ,
I will be lucky to see 5k a year, and our average yearly temp is 25c,I can not foresee to many problems,
cheers Peter
Quickss96
Jan 29, 2016 05:56 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Boss002
Jul 9, 2015 03:33 PM
