Electric W/P: Install a T-stat or no T-stat?
Old May 4, 2006 | 10:31 PM
FireFox5.0's Avatar
I bought a CSI Electric Waterpump and I am wondering if I should run a thermostat or just run it with out a thermostat. Would it be bad for the pump to run a t-stat?
I also got the Painless Electric Water Pump wiring harness and a Aeromotive 34% underdrive pulley. I figured since I had to reseal the timing cover anyways.... (the opti is new BTW).
Thanks for reading.
Old May 4, 2006 | 10:36 PM
Re: Electric W/P: Install a T-stat or no T-stat?
There have been a ton of posts about running/not running a thermostat. It does not matter if the pump is electric or mechanical. You should always run a thermostat in an LT1, IMO.
Old May 4, 2006 | 10:45 PM
matt65's Avatar
Install a T-stat
Old May 4, 2006 | 10:58 PM
firebirdStud's Avatar
do the 160 degree t stat. Works awesome in my car!
Old May 4, 2006 | 11:54 PM
FireFox5.0's Avatar
Thanks, that is what I thought but of course.... someone said it would burn something up, which of course to me sounded like BS but I just had to check.
Thanks.
Old May 5, 2006 | 04:19 AM
RE AND CHERYL's Avatar
The LT1 stat is different than other engines. It has a second valve that I beleive helps to recirculate water when the engine is cold. While I don't have any personal experience, I've heard from several sources that the car will overheat with it removed.
Re'
Nov 18, 2023 07:21 PM
robcarnut
Mar 20, 2015 03:40 PM
Queens94z28
Dec 20, 2014 09:11 PM
